how much spark advance is too much?
Old Aug 9, 2003 | 11:07 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I've been noticing that it's possible to advance my ignition timing an awful lot during high vaccum or part throttle operation before there is a noticable effect in the way the engine runs.
I can't give any specific numbers because I'm not using a distributor machine. But I'm thinking that at cruise, or about 2000rpm and 17" vaccum it will take between 30-40* of advance before it runs bad or stumbles.
How much can I advance my timing for low rpm/ low load conditions, to get the best economy?
Thanks in advance ...
Old Aug 9, 2003 | 06:03 PM
ede's Avatar
ede
try a dial back timing light to figure out your base and total timing, not a distributor machine. 34-38 degrees should be good for most SBCs.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Jorlain
Oct 8, 2015 01:57 AM
Jlanz55
Sep 9, 2015 09:09 AM
