need help quick just put starter in and...
just put a new high torque starter in my car. its made by cvr high performance. when i put it in the teeth look like they mesh good. but when i start the car it has the high pitched tgone like a high torque starter but when the bendix is supposed to release from the fly wheel it sounds like its catching. so.. i shimmed the starter and it sounds the same, what gives?? this starter is also i guess considered a mini starter also. do i need more shims? how can u tell? please please please any help at all would be great thanks
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Car: 4
Engine: 6
Transmission: 5
Probably needs more shims. Try adding them and see what happens.
I have one of those too, it's great. I can't believe I was so stupid and put up with the inadequate weenie stock POS and a car that would hardly start for all these years.
Car: 4
Engine: 6
Transmission: 5
Yeah, I have that starter too! I really like it. I have it on a 400, which of course didn't come with the late-model starter bolt pattern that you have to have to use with the T-5 bell housing, so I drilled my block. I purposely erred in the direction of moving the starter drive slighty closer to the crank, because I didn't know at the time whether this block had "The Problem" or not. (Turns out it doesn't) Mine is not very representative of what a properly-equipped block would have, therefore. It takes about ¼" of shims.
You can get packs of them in the Help! product line at the parts stores that have that, or ask for them at the counter. They come in 1/64", 1/32", and 1/16" increments usually. Try sticking a 1/16" in there and see what happens; if it's better but still needs more, add more; stop when it works right. Not very scientific unfortunately!
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
hookin- i think you would know already if you had a cracked block... you would be losin fluids and such...
Steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat.
Gonna be sellin the 86 in the spring to hopefully get an 88-92 formula 350, and supercharge it!! (amoung some other sweet mods)
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Steve
db057
Aug 11, 2015 10:11 PM
