Stumped
Old Aug 10, 2003 | 06:49 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
Stumped
ok, just finishing up my motor swap, installed my starter
made sure the wiring is correct........it is
made sure the large terminal always had power including when key is turned........yup
made sure purple wire on small terminal is getting power when key is turned..........yup
made sure the starter had a good ground against the block..........yup
so i replaced the starter solenoid with a new one
nothing
jumped the terminals with a screwdriver, nothing
tried it again, solenoid worked
then the solenoid worked with the key
then the solenoid stopped working
jumped it again
worked again when jumped
worked again when key turned
then it stopped working again after a few turns
all my connections are tight and clean
this is driving me crazy, any help would be great thanx
Old Aug 10, 2003 | 09:06 PM
Vader's Avatar
About all that's left is a ground connection, and the supply wires (fusible links) to the body at the starter.
Old Aug 10, 2003 | 10:40 PM
SlowMaro's Avatar
if hes getting power its nto a fuseable link, ...maybe you just have a bad starter .
Old Aug 11, 2003 | 05:40 AM
thanx guys,
the fusible links are ok
and i checked to make sure the starter had a ground
so tomorow night i am going to throw a new starter in
i dont understand why the solenoid isnt working though
i mean, it did work (and then stopped and worked again), and its brand new
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
