Cant corner hard anymore
Old Aug 10, 2003 | 10:45 PM
Big Juicy Z28's Avatar
Just swapped in an Edelbrock 650 cfm carb performer manifold and summit vaccum advance distributor, Problem is when i corner hard the car stalls I adjusted the Idle so its higher but that dosent help.
Old Aug 10, 2003 | 11:51 PM
SlowMaro's Avatar
your fuel pressure might be too low....what was in the car originally.
also, fuel pump might just be dying.
my car cuts off if i have a lil under 1/4 a tank and i stop really fast.. damn non baffled gas tanks!!!
Old Aug 12, 2003 | 11:36 AM
originally it the stock Q jet, I took the fuel pump out last week and i had a bent pushrod so i replaced it seems like the fuel pumps fine other than the fact that it leaks oil out of the Diaphragm
Old Aug 12, 2003 | 04:45 PM
SlowMaro's Avatar
fuel filter new? i still think its the fuel pump dying...if its leaking something, that means its not working properly..
Breazlan
Sep 25, 2015 11:20 AM
jerflash
Sep 23, 2015 09:21 AM
codeysabatini
Sep 20, 2015 11:36 AM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
Randomtask2
Sep 7, 2015 05:06 PM
