Need new radiator
Need new radiator
Its time for a new radiator and was looking for some suggestions. I dont really have the money for a BeCool or Griffin, I would like to keep it under $200, but would still like a good radiator. Any help would be great
Thanks,
Mo
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
Thanks,
Mo
90 IROC 5.7l (L98)
Transmission: 4L80E/4L80E
I picked up a new Modine for $145 at a local radiator shop last year.
Check www.partsamerica.com. They have a better deal ($119.99 minus 25% special they're running now). If you can pick it up at a local Kragen/Shucks/Checker, no shipping and no tax (small "handling" fee).
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
I looked at partsAmerica.com, and at the modine, it is a 1 row aluminum radiator, will that cool my car enough?
90 IROC 5.7l (L98)
90 IROC 5.7l (L98)
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i got a griffin from summit a 19*31 i think it was $185
86 camaro 405 sm. blk. th 350 tranny 3.42 gears
Car: 87Z
Engine: ?
Transmission: A4
Yes it will cool enough I just put one in and now I'm running to cool. Not getting nto closed loop at all. I run just a hair over 100 degrees.
87 Z28 305 TPI, Auto, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I still have a "new" (never used) 2-row radiator with metal tanks... I say "new" cuz I bought it to put in my car, bugared up a fitting, didn't have time to mess with it so I put another one in. Later on when I had more time, I got it repaired, so now it's all good. I do not recall what brand it is, I got it from a radiator shop for about $155. If you're interested, e-mail me. I'll send to ya $50+shipping.
KAM
KAM
I'm not putting out as much power as you are, so I waited for someone else to comment. But, if the stock radiator was doing the job before whatever problem you started having that prompted you to consider a new radiator, then the single-core replacement should do fine as well.
If you've got upgrade plans in the future that would increase power and thus the need for additional cooling capacity, then you should consider the upgraded radiator now.
they are both under $150 so price isn't too much of a factor here, so the copper brass 3 row would cool better than the aluminum?
thanks
90 IROC 5.7l (L98)
thanks
90 IROC 5.7l (L98)
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
When I replaced my factory aluminum one with the copper/brass three row. My temps went up about 10- 15* this was just a factory replacement I bought from a local chain.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
