Car died, only some electrical working
Old Aug 11, 2003 | 03:17 PM
GTA88's Avatar
I took the 88 GTA out to the beer store about 4 hours ago. Never made it. I got about 1 mile, then the car totally died, and I coasted into a parking lot, and got towed back to my house.
Here are the symptoms :
Turning key to "on" results in absolutely nothing : No guages, no fuel pump sound.
Turning key to "start" results in absolutley nothing. No crank.
Only things that work are : Dome light. Parking lights. Horn.
When I turn on the parking lights, the dash lights come on. I can move the gear selector around when the key is in "on" position".
No brake lights.
No headlights.
No turn signals.
No radio.
No power windows.
I checked all fuses in fuse box. All are OK.
HELP! All clues welcome !!
Old Aug 11, 2003 | 03:31 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
It sounds like it may be the inline fuse down on the starter wires. Happened to me once too. Same simptoms.
Old Aug 11, 2003 | 03:56 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Yep....an inline fuse, or more likely one of the fusible links off the starter terminal has either 'fried' or broken. There's usuually two on the terminal; one powers evrything that will work without the key being turned on (ie: lights, horn), and the other runs those things which operate with the key being in the 'ON' or 'ACC' position (ie: ignition, blinkers, radio).
Time to investigate...
Pete
Old Aug 11, 2003 | 05:26 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
yep, i second the fusible link, but more importantly, did you get the beer?
Old Aug 17, 2003 | 02:26 PM
GTA88's Avatar
Nope. Still haven't bought beer, but I've been able to survive on my reserve supply. Down to 3 cans though , definitely need a beer run tomorrow, in my other car. GTA still laid up.
I just checked the fusible links at the starter. There were 3 of them, each about an inch long and pill-shaped. They all looked fine, no melting, nothing unusual at all. The only other thing I noticed around the starter was that there were some copper wire strands poking out from 2 wires where they got connected together to the starter.
The 2 fusible links at the battery look good too. All fuses in the fuse box are ok.
What now ? Any other fuses or links to check somehere ?
MustangBeater20
Oct 29, 2022 09:20 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
