Is this a oil pressure switch problem????
Old Aug 11, 2003 | 09:35 PM
84 Challenge's Avatar
Started my Iron Duke Camaro today for the first time in a few months. Did not hear the fuel pump prime but after several cranks...she started! Maybe I'm not hearing the pump or it's very quiet. But anyhow...I can't hear it! Is this a sign of a bad oil pressure switch? One more thing, I swapped in a speedo/tach from my 83 Z parts car. Does the oil pressure switch also control oil pressure readings on the dash?
Thanks,
Brandon
Old Aug 12, 2003 | 01:28 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
That is a sign of the fuel pump relay going bad.
oil pressure swtich is what allows the car to start and run when the relay dies.
Old Aug 12, 2003 | 11:33 AM
Cool, thanks bro! So, the relay doesn't prevent the car from starting...I take it?
Brandon
Old Aug 12, 2003 | 03:03 PM
Zepher's Avatar
Brandon
No problem.
The relay is the main power feed for the fuel pump and the oil pressure switch is there as a backup.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
TA8487
Aug 16, 2015 12:21 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
