Question about sensors mounted in the heads.
Old Aug 12, 2003 | 03:05 AM
luxor's Avatar
Car: 91 Formula
Engine: 357 TPI
Transmission: WC T5
I'am pulling the 305 out of my 91 Formula to replace it with the 357 I have sitting on the stand. The drivers side head has the coolant temp sensor while the passenger side head has a sensor in the same hole as on the drivers side. This sensor has the same type of connector (flared top, single conductor, push on, squeeze sides and pull to remove) that is used on the knock sensor located below it on the block. Does anyone know what this sensor is used for. I tried to remove it but it is frozen tight in the head. Since the heads are mirror images of each other I assume it projects into the water jacket, therefore it must but used in conjuction somehow with the temp sensor on the other head but here it's just conjucture. Does anyone have a clue because I'am at a loss. Thanks in advance.
Old Aug 12, 2003 | 03:45 AM
luxor's Avatar
Car: 91 Formula
Engine: 357 TPI
Transmission: WC T5
I think I found the answer to my own question. I believe it is the fan switch. If I'am wrong could you please confirm. Thanks!
Old Aug 12, 2003 | 04:49 AM
ede's Avatar
ede
temp gauge left fan switch right
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
timonator
Aug 11, 2015 09:56 PM
