mod plan
Old Aug 12, 2003 | 09:35 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
mod plan
ok this is what i plan to do
Holley SysteMax street performance pkg. that includes:
-Lunati Hydraulic Camshaft with lifters
218*/218* @.050
268/268 advertised duration..not sure what that means ???????
.457"/.457" Lift
110* Lobe seperation
105* Lobe centerline?
dual plain intake manifold.
Summit Roller rocker arms 1.5 ratio, 3/8" stud
comp cam valve springs and
Holley Streeet Avenger carb 570 or 670 cfm with electric choke
OR
Summit Cam kit
214*/224*
.442"/.465"
Lobe seperation 112*
Good for RPM 1,500-4,000
Summit rockers-same as above
Holley Street Avenger carb, same as above.
My question is this, will this setup work?
85z28, 305 4bbl, auto, with shorty headers, hi output ignition, chrome aircleaner....
I am not going to be racing my car, just want it to sound and run like its got some bawls Ive been thinking about this system and it seems ok but i wanted some advice as to if i should still go smaller on the cam and maybe the carb to? I dont wanna go with a 204 cam maybe a 212 will be ok though. This is the most major mod i will be doing, i dont plan on changing the heads just some of the valvetrain. Please advice and opinions, yes i said opinions are appreciated.
Old Aug 12, 2003 | 11:38 PM
2 dope's Avatar
Engine: 305 LG4
hmm usually everyone has an opinion to give lol
Old Aug 12, 2003 | 11:42 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I would go with the summit cam if you have to choose between those two. I like the Compcam 212/218 better for the 305.
ZZ3Astro
Aug 13, 2019 12:57 AM
mfp189
Sep 27, 2015 09:25 AM
R13_Braz
Sep 18, 2015 05:00 PM
