ok so wut about this setup??
Old Aug 13, 2003 | 11:00 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
ok guys I have wuts in my sig and i'm not making much usable power cause my heads are killing me, now say i went with a smaller cam, Do you think i coudl make more power?? Also if not then i am gonan save for a set of Vortecs from sdpc machined down already, a perf. RPM intake, same 750 edel i got now, and i was think maybe an XE-268 or do you think an Xe-274 woudl be better?? I am looking to be able to get into the 12's with this motor and some 3.73's on street tires. and i mean street tires by liek normal tires u drive on everyday liek a futura gls or ultra-z or something. thanks
Old Aug 13, 2003 | 11:11 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
""s/r 1.94/1.50 heads""
Start here, either upgrade or work these heads. There should be enough meat to remove to support 450HP, probably more.
Ofcourse if you have the $$ (you'd obviously not be MWC) you could look in to buying a set of better heads.
Seems like you have a strong carb cam, but I'd still want more lift
Old Aug 13, 2003 | 11:21 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
unngghhh... futura tires are horrible. I put my vote in for a smaller cam like the xe268 and work the s/r's over. It probably wont be enough for 12s but it sould still do low 13's pretty good, not to mention your t5 will be history if you go much further.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
