speedlimiter
Old Aug 14, 2003 | 09:35 AM
nathan2003's Avatar
Car: Camaro
speedlimiter
on the 305 TBI there is that speed limiter right ?? well i started ****in cuttin wires to my computer trying to get the right one and i can't find what wire it is... and now i gotta *** damn mess of nothing but cut wires everywhere like 5 green wires are cut and still cant find the right one.... anyone help?
Old Aug 14, 2003 | 10:15 AM
MasterEvilAce's Avatar
umm
bad way to go about things..
there's a tutorial on this site about making a switch to turn it on/off
but i think that you can't use your speedo when you activate it.. can't remember
i think you can get a custom PROM that disabled the speedlimit
Old Aug 14, 2003 | 11:22 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
that was a bad idea, the way to disable the speed limiter is to find the VSS wire that leads into ur ecm, and cut that one, solder some wires onto both cut sections, and put a simple on/off switch on the other end of wires, so that when u want to fly, just turn the switch off, and the ecm wont be able to tell how fast ur going, so it wont try to limit the speed
Old Aug 14, 2003 | 03:12 PM
deadtrend1's Avatar
A custom E-prom and the switch method are the 2 ways to disable the limiter.
I don't really know what to say about the method you tried. Theres usually never exact same color wires. If you have 5 greens like you say there should be a variation. Green with a orange stripe, black stripe, brown stripe, & so on.
SMOKIN92RS
Sep 15, 2010 10:52 PM
pascal_91ta
Mar 13, 2008 06:12 AM
firebird896
Dec 26, 2007 08:16 PM
REVLIMIT
Mar 23, 2001 09:32 PM
