How to set valve lash with a solid cam
Old Oct 30, 2000 | 12:58 PM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
How do I set valve lash with a solid cam?
Old Oct 30, 2000 | 04:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
e-mail me...
Old Oct 30, 2000 | 04:46 PM
ede's Avatar
ede
feeler gage between the valve tip and the rocker. your manual will tell you what valves you can run without having to turn the engine for each pair of valves.
-=ICON MOTORSPORTS=-
Old Oct 30, 2000 | 06:48 PM
BOWTIROC's Avatar
Yes, I know about the feeler gage, but do I tighten it till I just feel tension on the pushrod?
Old Oct 30, 2000 | 06:50 PM
ede's Avatar
ede
the feeler gage should slide out with a little resistance, but you shouldn't have to force it, and it should slide back in between the valve tip and the rocker.
Old Oct 30, 2000 | 08:19 PM
Vader's Avatar
Don't forget, the engine should be HOT to adjust solids. As the guys advise, a slight drag on the feeler as you pull it out of the gap should be all that's necessary.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
cstrobel65
Aug 15, 2015 10:19 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
