anyway to get alternator pully bolt of.
Old Aug 15, 2003 | 06:31 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
I need to change switch my pullys for my alternator but i can never seem to get the bolt off without an airgun.
Any idea's on how to do it manually?
Old Aug 15, 2003 | 08:52 PM
Scott C-2
Guest
Posts: n/a
With the alternator mounted and the belt installed for a little extra tension, carefully, but firmly, wedge a screw driver or similar against the back of the pulley and the case, then loosen the nut...worked for me, but may not for you.
Old Aug 15, 2003 | 09:03 PM
Vader's Avatar
A strap wrench can help hold the sheave/fan as well, but it's a lot easier on the engine or with the rear half of the case removed.
Old Aug 15, 2003 | 11:35 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
well this is the story...
i got a new alt from napa. everytime i get a new one i have to switch the pullys cause i have a v-belt. so i switched pullys,put on new alt everything is ok for like a week. I return old alt for core $.
Now I go to drive the car the alt is draining my battery again,this was the problem with the 1st alt.
so now i need to return the alt that is on there and and get a new one but I need to switch the pullys. I can get the one off the car now but i don't know if they will let me exchange the alt without a pully. I don't think Will be able to get the pully off the new alt i get from napa.
any ideas?
Old Aug 15, 2003 | 11:53 PM
icebird_1981's Avatar
this v-belt thing u are talking about what does it look like??? i also keep snapping my altinator belt, its not lined up perfect i think i need a diffrent pully.
Old Aug 16, 2003 | 02:25 AM
rjmcgee's Avatar
Alot of the parts stores can change the puley for you. Usually an air impact gun does the trick.
Old Aug 16, 2003 | 07:30 AM
ede's Avatar
ede
all parts stores around here, AZ and napa will change the pulley for you. if they won't or can't try the strap wrench.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
