Won't start
Won't start
I put a salvage yard motor in my camaro. The old motor ran before I changed it out. Now the car won't start. The engine turns over. After trying to start I pulled a plug.n It was dry. The fuel hoses seem to have pressure. I didn't see a spark at the spark plug when laying it on the plenum after pulling. Is it possible that I have the fuel hoses to the fuel injection mixed up? On the coil there seems to be one lead to the distributor (spark plug type wire) and then two female connections. I have only found one wire (male connection) that plugs into this. Is there supposed to be two connection? This is a 2.8 liter V-6. I am using the same coil that was in the car when it was running. I changed the distributor cap, plugs and wires. I did not change the rotor. Thanks for any help
