problems installing Energy Suspension trans mount on stick cross member
Old Oct 31, 2000 | 03:28 PM
Get Blown ?'s Avatar
I'm in the middle of installing it right now and the bolts won't line up to the cross member. I've been fooling around with it for the last hour and it's freakin cold out. Anyone have any tips to help me? I'm about to give up and throw on a cheapo mount...
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Old Oct 31, 2000 | 03:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is this the same mount for automatics? I thought they were different for manual trannies.
At any rate, after I dropped & reinstalled my trans (when I had it rebuild, AGAIN), I couldn't get the ES mount's bolt to mate with the trans. I wound up removing the mount from the trans, putting the mount bolt through the crossmember, screwing the mount onto the trans, then tightening down the crossmember.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 31, 2000 | 03:43 PM
Part number 1108 or that's the one I was told to get.
BRB I'll check if that'll work for me, anyone who has any other opinions I'm all ears.
Old Oct 31, 2000 | 03:58 PM
Yarnboy's Avatar
Talk about a bitch! I had the same problem..I couldnt get the bolt they gave me to thread into the hole easily..I made it..I was so pissed off..I kow this isnt help AT ALL but just letting you know I feel your pain and it sucks and I just screwed it in and I dont think it's ever coming off. Good luck!
-Red '88 IROC 5 Speed TPI
-Dual Friction Centerforce Clutch
-Accel 300+ Racing Ignition
-Accel 300+ Pro Sleeve Plug Wires
-Accel U-Grove Plugs
-Flowmaster Force II 3 Chamber Cat Back Exhaust
-Hypertech Chip
-Hypertech Airfoil
-Removed, Then Re-installed (out of fear) MAF Screens
-Gutted Air Box
-Best E/T 14.90, 60 ft. 2.17, 1/8th mile 9.61(bald tires, SES light on)
-Best MPH 92.7(bald tires)
Old Oct 31, 2000 | 05:23 PM
merf23's Avatar
the easiest way...
1) remove crossmember, let trans hang
2) remove old mount
3) bolt new mount to trans and tighten
4) bolt crossmember to mount (leave loose)
5) jack up trans and bolt crossmember to chassis (leave loose)
6) align all holes from crossmember to chassis and crossmember to mount so they are centered, then tighten
Trying to do it without dropping the crossmember is what is called "P!ssing into the wind" (sorry minors)
Old Oct 31, 2000 | 05:29 PM
Still no luck. I got pissed and threw on old mount for the night, too dark to see anything now. Might take a final crack at it tomarrow or it's going back.
customblackbird
Aug 15, 2021 10:16 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
The_Phoenix
Feb 4, 2016 07:10 AM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
