Tick tick goes the engine
Old Aug 16, 2003 | 06:11 PM
Longer91Cam's Avatar
Car: 91 RS
Engine: 305 TBI
After the engine has been off for a while and then started back up there is a ticking noise that can be head inside the car and out. It gets louder under acceleration and then eventually goes away and doesnt reoccur until shut off again. What could this be? Exhaust leak or something else?
Old Aug 19, 2003 | 11:14 PM
Car: 91 RS
Engine: 305 TBI
Anyone please respond
Old Aug 20, 2003 | 05:46 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
oil starvation,whats the pressure at? my v6 did the same thing,a good fix is to run a can or 2 of liquid wrench through the motor ,let it run for about 15-20 minutes,then change the oil,it removes all the gummy deposits and sludge.
Old Aug 20, 2003 | 05:59 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
It could be an exhaust leak. My brothers 89 Iroc did the same thing. Found out that one of the nuts came off the exhaust manifold where it meets the y-pipe. He would start it and the ticking noise could be heard. After a few minutes when the pipes had gotten hot and the metal expanded, the noise was gone.
Hope that helps.
Old Aug 20, 2003 | 06:01 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
yep its probably oil havin trouble makin its way up the pushrods.. its almost always caused by poor maintanence (oil not changed often enough) you probably a good amount of sludge buildup inside the engine.. the liquid wrench method is new to me but sounds believeable... more common is running a quart of atf with 4 quarts of oil to clean everything out and then drain and refill with clean oil and a new filter.
Old Aug 20, 2003 | 06:18 PM
Transmission: t-5
yeah,the liquid wrench came from my teacher,i go to arizona automotive institute, so its not some BS,its something they did all the time he said. it worked wonders on my v6
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 7, 2015 09:55 PM
