Honest Emissions Question
Old Nov 1, 2000 | 07:44 AM
Brett's Avatar
I've been told that here in Connecticut I can fail the test. I have to go to a mechanic and then bring the receipt to prove that he worked on the car back for the 2nd test. If I fail again I pay a $150 fine and I'm out the door with a 'Fail' sticker. This sounds too good to be true?
I have a couple of buddies who would give me some fake documents to show the flunkies at the test center if need be. And in my opinion $150 every two years is well worth the ability to run the most radical cam possible and make GOBS more power.
Who has experience with failing emissions?
I know I should call the local test station or something but knowing that they produce revenue unjustly for the state I would be leary of them having caller ID and them somehow finding out that the car is like a year late (been down for the swap, then I blew the engine).
1991 RS LT1
every imaginable bolt-on, ungodly LT1 355, and 12 pounds of intercooled boost on it's way in '01
2000 C5 Coupe
black/black 6-spd, optional polished rims, first run 13.056 @ 109.52 stock
"So what DOES the back of a Mustang look like?"
Old Nov 1, 2000 | 09:02 AM
Nightcruzer's Avatar
Car: Trans Am
New York has something similar. If you can show/prove that a "professional licensed mechanic" tried to fix the cause of your failure, then you are good for a year. It's just too expensive at $400 per year. Anyway, check Connecticut's DMV website, The NY DMV website explains the process all in detail.
1983 T/A LG4 w/T-tops
Rebuilt/Modified E Q-jet
Custom Dual Ram-Air
Self painted cherry red w/ restored black/grey interior
Welded Comp Eng SFC
Tokico Struts/Shocks
Hotchkis LCAs and Panhard Bar
Energy Suspension bushings all around
Old Nov 1, 2000 | 11:54 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Mass. has the same thing going on. I heard that mass. is like 3rd or 4th in the nation now for emissions, after CA and NY I believe. They have the same deal in MA where if you fail, you have to attempt to repair or resolve the problem. What I did, is in MA, they can fail you for not being stock, so I just put in a much tamer cam for the inspection, then I changed it back out again right after. My engine isn't a 305 which is what the 89 RS came with, but all I had to do with that was put an "emissions" device over the tag on the block. I don't think that they actually looked that hard, but hey you never know. I'm sure that you could call up the DMV and ask, it seems a little paranoid to think that the DMV is going to be out chasing all of the hot rodders in CT, I mean where are they all gonna hot rod to? The state is only so big! Just kidding.
I do know a lot of people though that know a mechanic and will go in there and just keep paying the $150, but it seems a lot cheaper to change out the cam for the inspection, and then to slip in the new one. In my car, I can work on the cam with the motor in. I don't know about firebirds or the slightly newer camaros though...
-=-Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, platinum plugs, chevy caprice 350 chip.
69 Six Pack
Oct 5, 2015 07:51 PM
z28addict8490
Sep 5, 2015 03:56 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
