383 build up, see if I am doing this right>
Old Oct 31, 2000 | 06:34 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
This is my first 383 TPI build up. I am going with the list below, so please tell me where I am going (if I even am) wrong. Remember, I just want to see at least 12.3's in the 1/4 mile with this set up (no NOS).
383
11.1 forged pistons
forged crank
forged rods
AFR or Canifeild 195cc heads
bigger injectors (not sure how big)
New PROM to go with new set up
*Mini ram? Super ram? Better flowing TPI?
SLP's 224/230 cam
1.6 roller rockers
----------also-----------
AFPR
MSD 6AL
headers
2.5" dual exhaust
2800 stall
3.73 gears
Well, I need to see low 12's with this set up. That way (seeing its going to be forged) I can run anywhere from 150-225 shot NOS, single or dual stage. Then I should pull 11's all day.
*zip up flame suit*
25th Anniversary Z28
[This message has been edited by GOFASTER (edited October 31, 2000).]
Old Oct 31, 2000 | 07:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I ran 11's on just the engine (carbed) with less than that but then the stock bottom end finally let go.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Old Nov 1, 2000 | 10:11 AM
GOFASTER's Avatar
Engine: 388 ci
So that sounds about right? I hope to one day see high 10's, but that will come with the right amount NOS That and a good stong 383.....
Old Nov 1, 2000 | 11:35 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Why NOS, why not go with a super-charger?? At least you are not refilling the NOS tank all the time. Get the super-charger, and if it still isn't fast enough, then you get the NOS.
The list of what you are going to do, that is pretty much what I expect to get done over the next 3 yrs, including the super-charger, and alot of suspension mods. I am not interest as much as a lot of people in their 1/4 mile times, I just wanna roast any and every mustang on the road. Whether it be straight line or in the twisties.
Godti
'89 Trans Am (Red)
305 TBI 5spd
[This message has been edited by Godti (edited November 01, 2000).]
Old Nov 1, 2000 | 01:18 PM
GOFASTER's Avatar
Engine: 388 ci
If you look at long term, the supercharger may be almost the same (over time) as the NOS. The NOS gets pricey becuase it first costs around $600 for the kit, and like $30-45 every time you fill it, over time that filling the bottle gets pricey. Tthe supercharger is like $3000, then it uses more gass, so over time they both cost alot of money. But, I want to just run all motor, along with NOS, (besides I already have the NOS system).
UltRoadWarrior9
Apr 28, 2020 10:39 PM
83RDRACR
Mar 26, 2016 08:13 PM
Jorlain
Oct 8, 2015 01:57 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
