New TCC solenoid ?
Old Aug 17, 2003 | 09:18 PM
Daemorok's Avatar
New TCC solenoid ?
I had a manual Torque Converter lockup switch, and it stopped working.
I posted about why, probably a few weeks ago and someone mentioned the TCC solenoid.
So my question is how hard is it to replace the TCC solenoid, and where is it exactly, oh and about how much to they cost.
my tranny is a 700r4
Old Aug 17, 2003 | 10:40 PM
Vader's Avatar
You can access the solenoid and connector from the pan. Remove the pan and filter, and you should be able to see the connector through the trans housing and follow the wires to the solenoid in the valve body.
Old Aug 18, 2003 | 07:01 AM
Daemorok's Avatar
hmm.. is there a way i can test to see if its working, without opening the trans ?
Old Aug 19, 2003 | 08:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can check for continuity across the connector pins. Good luck getting to them, it's tight up there in that tunnel. I tried, found it was easier to drop the pan (you need to change the fluid anyway, right?).
You could short the sockets in the ALDL (look in the tech article about manual lock-up switch to see which ones to short), listen for the click.
You also need to make sure it's getting power (turned out that was my problem). And, there's a pressure switch in series with the solenoid (4-3 switch) that's normally closed, if it has failed, no lockup.
The easiest way to check all these things (except the ALDL trick) is to drop the pan.
Old Aug 20, 2003 | 02:49 PM
Daemorok's Avatar
The ALDL is where i had the manual switch hooked anyway.
Would I be able to try this with the car on accessory?
cause when its running there is no way i could hear anything.
Old Aug 20, 2003 | 05:34 PM
five7kid's Avatar
Check it with the ignition in the "on" position but without the engine running.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Quzyle
Oct 15, 2015 03:35 PM
92camaro350cci
Oct 14, 2015 09:29 AM
mcbitchman
Sep 29, 2015 12:32 AM
ramicio
Sep 28, 2015 01:18 PM
