Sputter dead
Old Oct 31, 2000 | 08:43 PM
Trnsam87's Avatar
Sputter dead
Hi all, Im having some problems with the 87TA.Maybe someone can help.It will
fire up and run at idle for about 10-15 seconds, then all of the sudden rpm
will drop and the car will just sputter out.If i try to keep it up by
gassing it it stays alive but runs extremely rough.If i let the gas off,
sputter down then dead.I replaced the coil (HEI) and replaced 3 of the 8
plugs.I am gonna do the rest of the plugs tommorrow.Thus far i have a fairly
new battery, new fuel pump,fuel filter, fairly new rebuilt carb, 6month old battery, new
alternator, new plug wires.Any relies is greatly appreciated.Thanks in advance ~~Jaime~~
1987 TransAm
350 sbc
Holley 750 Vac sec
Edelbrock Performer Rpm Heads/Intake/Cam
Flowtech Ceramic Headers
Crane Roller tip Rockers/pushrods
Flowmaster Muffler
Old Oct 31, 2000 | 10:55 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Try unplugging your MAF and start the car. If it runs for lots longer - or not, come let us know.
Old Oct 31, 2000 | 11:05 PM
CamaroZ_85's Avatar
sounds similar to whats happening to my car right now. take the air cleaner off. have a friend start the car, and then hold your hands over the top of the carb, blocking off the air flow. if the car runs better/normal, you have a vac leak somewhere. if all the hoses check out ok, spray some carb cleaner or ether or something similar on the carb itself and around the base of it. if you spray an area and notice that it runs better, this is where your leak is. btw it turned out that the base gasket was leaking on my carb, replaced it and still had crappy idle. sprayed around the carb and learned that ive got quite a few vac leaks in the carb itself so its time for a rebuild.
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old Nov 1, 2000 | 04:33 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Doh! Let me exit stage right to kick myself in the *** a few times!
Old Nov 1, 2000 | 05:50 PM
Trnsam87's Avatar
Lol Red devil.Its all good.Thanks for the replies guys, it turned out to be a vacuum after all.Hard to explain, but im basically having to modify my current Vacuum fittings to my carb in order to make it run right.Thanks again ~~jaime~~
1987 TransAm
350 sbc
Holley 750 Vac sec
Flowmaster Muffler
db057
Apr 28, 2019 07:45 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
Jonas Earl
Sep 27, 2015 07:39 AM
