help! custom pistons and rods or 434 stroker?
Old Aug 20, 2003 | 04:26 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I cant make up my friggin mind now. I have an HT383 I'm thinking of supercharging(sn-89 paxton), but to do so I'd need custom pistons and rods, about $1000ish. I have a .040 over 400 block at home I was holding onto to build a 434 stroker, whereas kits I've found are in the $1450ish range, plus retrofit lifters. Too radical? Since I'm still MAF TPI (LT1 intake), what the hell should I do? Too many choices. I'd end up using the parts I have now. Any suggestions? If I did the 400, it would be a roller motor, with an aggressive blower cam, something similar to the cc306 cam, using my pro topline 200cc aluminum heads. Any ideas? I'm looking for about 700 streetable HP if I go supercharged, 525 without.
Old Aug 20, 2003 | 08:47 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I say put the 3.80" stroke 383HT crank in the 400, and make a nice street motor out of her. IE lots of torque = lots o-fun.
Old Aug 20, 2003 | 09:44 PM
dhirocz's Avatar
Cant do that. All factory 400 blocks are 2 pc. RMS's, while this one is a 1 piece. Sucks. So if I were to do the 400 I'd have to spend the money on a crank kit and retrofit roller lifters. Sux. I could go nuts and put in a 327 crank or even a 302 crank, but if I were going to do that, I'd carb it and install 18* heads and a really really big cam with a TH400. Not looking to drag race too much.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
