3.42 swap and speedo gears
Old Aug 21, 2003 | 09:30 AM
Cole's Avatar
I swapped my rear gears a while back. Not long thereafter I changed my speedo gears to correct my speedometer. Now, years later, I have to replace the speedo gears again due to the clip on the tailshaft failing and chewing up my gears. So, what is the best speedo gear combo for a 700r4 and 3.42's in the rear? I have 215/65/15 tires. I thought that I should use the 15 tooth drive gear and 41 tooth driven, but TCI says to use a 40 tooth driven gear. Which is correct. Thanks.
Old Aug 21, 2003 | 08:52 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I don't know which would be better, but I would say maybe check out a factory thirdgen with 3.42's and see which it uses
just a thought.
Old Aug 22, 2003 | 10:18 AM
25THRSS's Avatar
just a thought.
Aren't all factory 3.42 cars 5 speeds or would that not even make a difference?
Jorlain
Aug 24, 2022 05:11 PM
draco
Oct 4, 2015 09:25 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
