how much hp do I need?
Old Aug 18, 2003 | 12:27 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
How much hp do I need to run low 12's in the 1/4? It's a 5 speed tpi thats 3600 pounds any thoughts would be helpful! thanks alot!
Old Aug 18, 2003 | 12:51 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
at least 400 rear wheel horsepower.
Old Aug 18, 2003 | 03:01 PM
I didn't think I need that much ! So what's the best way to get that much power and still be california emmisons compatible.
Old Aug 18, 2003 | 03:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
More than your T5 can take.
Old Aug 18, 2003 | 03:52 PM
Was thinking g-force 5-speed. or t-56.
Old Aug 18, 2003 | 07:22 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd say around 350 to the wheels.
Old Aug 18, 2003 | 07:53 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
3600 lbs
12.2 secs
18% drivetrain loss
391.8 rwhp
477.8 fwhp
Old Aug 18, 2003 | 08:22 PM
Jim85IROC's Avatar
all depends on your weight and your suspension. There are some nearly stock LT1s out there running mid/low 12s with nothing but suspension mods. They are putting way under 300hp to the rear wheels.
Old Aug 18, 2003 | 09:39 PM
thanks for all the replys!!
Originally posted by rustybluebird
3600 lbs
12.2 secs
18% drivetrain loss
391.8 rwhp
477.8 fwhp
rustybluebird, how did you find out those numbers? 12.2 is exatly want I would like to run!
jim85iroc, I will be runing ever aftermaket bolt-on thing there is for the suspension.
And another ?, what would be the best way to do it. All motor, nos, or blower? and still keep it very drivable and some what good on gas.
and thanks to everyone whos replying, and keep them coming!
Old Aug 18, 2003 | 10:38 PM
Car: 87 Firebird
some formulas
Old Aug 18, 2003 | 10:53 PM
some formulas
Thank you so much, just what I been looking for!:hail: :hail: :hail:
Old Aug 19, 2003 | 02:56 AM
OMINOUS_87's Avatar
Traction will make or break you. It takes alot more then power to run fast. Keeping an engine in its power band while being able to hook at the same time are eqaully important as hp numbers.
Old Aug 19, 2003 | 09:41 AM
87LTcamaro's Avatar
go all motor to the 12s......that way you know your motor can do the work.......then you can supercharge, turbocharge and know that your motor can take it. i would get some lighter wheels and some good rubber......cuz it is hard to hook up thirdgens when youve got the power to run 12s. good luck.
-Ryan-
Old Aug 19, 2003 | 09:44 AM
87LTcamaro's Avatar
oh yea as far as the good gas mileage.....learn to tune your TPI to your engine and youll get really good gas mileage. 16-18mpg. its all about effeciency.
-Ryan-
Old Aug 19, 2003 | 01:45 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Look at it this way. Stock LS1 cars can run VERY low 13's on street tires, and some do hit 12's with only slicks. The typical LS1 camaro or firebird will weigh over 3600lbs without a driver and they have around 350hp and 380ft-lbs at the fw. A 3rdgen car will weigh alot less probably, especially if its been prepped for racing. As it is now, my '83 Z28 weighs around 3200lbs and has a basically stock weight engine (all iron 350 except intake) thats w/o driver BTW.
Now.. if your car has been prepped for racing (stripping accesories, dead weight, etc) it will weigh about the same as or less than mine, which is 400lbs less steel for the engine to move compared to an LS1 car.
So if you want to do 12.99 or faster, i would say you'd start at 400hp/400tq at the fw to get there, and only up to go faster.
They are right though, if you wanna hit low 12's, you will need around 475-500fwhp to gte you there.
Old Aug 19, 2003 | 02:30 PM
It's going to be a daily driver with everthing(back seat, a/c, and stuff like that).
So I need alot of power, but whats the most effecent way to do it for a daily driver.
And thanks to everyone who has replied, you have been most helpful!!
Old Aug 19, 2003 | 03:45 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The easiest and cheapest way would be to build
a 300hp 350cid engine and use a 100hp shot of nitrous.
Old Aug 19, 2003 | 04:45 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
but think if you have the cash to spend if you do build an all motor low-mid 12 second car then spraying would dip you into the 11's oooo now wouldnt that be fun.
Old Aug 19, 2003 | 06:27 PM
I was thinking nitrous, but was warey of using it on a stick car.
Old Aug 19, 2003 | 06:33 PM
zippy's Avatar
Engine: 5.3L
for a daily driver, i'd say a mild 355 with a 144 blower on it. they make for a nice driving, nice idling, fairly inexpensive combo that has power at all rpm.
Old Aug 19, 2003 | 06:36 PM
will that pass smog?
Old Aug 20, 2003 | 09:02 PM
zippy's Avatar
Engine: 5.3L
if done correctly, most certainly. you could probably even get a 305 into the 12's if it were well set up with a 144 blower.
Old Aug 22, 2003 | 10:20 AM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
California sucks my a$$. Nothing will pass smog. Nothing. Nothing fast anyway. I live here and my stock 305 TBI wouldnt pass, because my CAT was rotted.
Gotta love the Golden State.
