305 parts list / power increase ?
Old Aug 21, 2003 | 09:58 PM
nathan2003's Avatar
Car: Camaro
alrighty i have a bone stock 305 TBI with flowmaster exhuast.... and i just purchased all these parts and am wondering what my result will be...
I just got a Edelbrock Torker Intake Manifold, Edelbrock Performer Series Carburetor 600 CFM Electric Choke, Comp Cam - High Energy Cam 268H, headers are yet too come...
anyone give me an idea of power increase i'm lookin at ??
Old Aug 22, 2003 | 10:30 AM
Vader's Avatar
Nathan,
I'm hoping that your Comp Cam is a kit, including new valve springs. You may also want to check the guide/retainer clearance very closely. A 268H will have net valve lifts beyond to the limit of stock heads, and beyond the limits of stock springs.
Another thing you may want to check into before you start the project is your head casting numbers. I'm not sure if the later TBI engines still used the swirl-port design, but if they did you gains will be minimal.
In short, gather some more information, plan the job completely, then begin. You may find that you'll be shopping for a pair of used heads to prepare for your new cam and other modifications.
Incidentally, you'll probably want to install screwed rocker studs with that cam and the appropriate springs. You'll also need to verify if the intake is machined for the older or newer style heads. The two middle intake flange bolts on both of your stock heads will be drilled at a 72° angle to the flange instead of a 90° angle like older heads.
Old Aug 22, 2003 | 02:15 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
i was gonna use the same lift but thats too big, go with maybe a 204 or 212
Old Aug 22, 2003 | 02:16 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
204 and 212 would typicaly be duration numbers not lift.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
customblackbird
Aug 15, 2021 10:16 PM
1nastygta
Aug 8, 2015 07:38 PM
