engine almost dies while braking
Old Aug 22, 2003 | 10:52 AM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
my engine runs really great with no problems aside from this. if i brake lightly it is ok. however when i brake pretty hard, my engine will almost die, (rpms drop to 200) but then comes back. is this a vacuum leak?
Old Aug 22, 2003 | 11:08 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
It 'could' be....
You definitely need to utilize a vacuum gauge while the car is in gear....
It could be one of two things bro;
1) With the car idling, hold you're left foot on the brake very firmly, then with the right foot, mash the gas.... then release. If it wants to stall, then yes, you have a vacuum leak!
2) If she wants to stall ONLY after braking, as well as after you make a turn.... then it's the float in the CARB, she's probably set too low, especially if you added to the engine.
But if she's a new crate engine, then it's probably somewhere in the vacuum lines.... where's you're brake vacuum hooked up?
Old Aug 22, 2003 | 03:54 PM
cr125r's Avatar
Car: 1988 trans am
Re: It 'could' be....
Its definately #1. i have it hooked up to the port on the back of the 650 dp carb. whats the best way to check for leaks?
Old Aug 22, 2003 | 04:06 PM
Re: Re: It 'could' be....
With the car idling.... spray some CARB Cleaner around the intake manifold bolts, as well as by the CARB base. Once you hear the engine 'rev up', this is the area where you're vacuum leak will be....
If possible, if you're not utilizing the vacuum port on the intake manifold itself.... get you're hands on a fitting for it, then hook the brake line to the new fitting on the intake manifold (only if no vacuum leak is detected though.... otherwise just correct the vacuum leak, and leave the brake vacuum line where it is).
Old Aug 22, 2003 | 05:17 PM
cr125r's Avatar
Car: 1988 trans am
i will do this tomorrow, thanks
Old Aug 24, 2003 | 12:28 PM
cr125r's Avatar
Car: 1988 trans am
question. on a 650 holly dp, where does the brake booster hook up? i put it in the big posrt on the back of the carb...shouls it be there or in the intake manifold????
Old Aug 24, 2003 | 06:31 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
it should go onto the intake man...
Old Aug 24, 2003 | 09:41 PM
cr125r's Avatar
Car: 1988 trans am
the carb hangs over the hole in the intake where it is supposed to go, it the only place i can think to put it. is it ok to have it connected on the carb?
Old Aug 25, 2003 | 05:38 AM
They have fittings that are angled at 90°, you'll have to remove the CARB, add some thread sealant to the fitting, then simply install it...
But, if you're brakes are working okay, and you found you're vacuum leak, then the above is optional.... however, you get a much stronger vacuum pull from the intake.
Old Aug 25, 2003 | 06:01 PM
cr125r's Avatar
Car: 1988 trans am
well, i found it. turns out that the hose by the distributor cracked a little, so it wasnt visible. i replaced it and all is well again. thanks for all your help!
Old Aug 25, 2003 | 07:32 PM
Excellent!!
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
