how do I remove the dang rotor????
Old Aug 22, 2003 | 04:18 PM
asylist's Avatar
car-92 Firebird with the 3.1L engine. Replacing cap and rotor, or at least attempting to. Dang rotor feels like its welded to the dist shaft. I remember having the same problem on the same type of dist on my 91 Sonoma. Tried prying it off with a screwdriver, ended up breaking the reluctor ring and had to buy a whole dist to get that one part I would prefer not to break anything but the rotor this time around. How do I get this thing off?
Old Aug 22, 2003 | 07:11 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If it's anything like my 3.1, it should just pull right off. If it's been on there for a while, it may take some tugging to get it to come loose. Try tapping it lightly with a rubber mallet, and keep pulling on it firmly, but not too rough. When you go to set the new one in place, be sure it goes all the way down on the shaft, or else you can and will end up with a chewed distributor cap. Good luck.
Old Aug 22, 2003 | 08:01 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: how do I remove the dang rotor????
Yes, they do weld themselves on there. IIRC the last time I used a pry bar over the back of the plenum and under the rotor. Used some cardboard to protect the plenum and common sensor as to not pry so hard to damage the plenum or distributor.
On one I pulled the distributor out and used (carefully) a hacksaw on the rotor. I don't know why they get so attached to the distributor so I now use a film of silicone grease on the top of the distributor shaft.
RBob.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
RyanJB
Sep 2, 2015 01:27 PM
