Screwy Transmision Question.... !!
Old Aug 22, 2003 | 07:43 PM
nathan2003's Avatar
Car: Camaro
alright i have the 700R tranny or whatever it is... anyways its an automatic and well lets say i'm going 70 down the highway and something comes up and you gotta stop fast... *just usin this as an example* so what do most of you do hit the brakes and **** from OD to D and the car will go up in rpm to high rpms cause your going down a gear then you go to 2nd if you havet to and then the motor is really screamin if your going fast that is..... just like an engine brake... helps you slow down and ****... well anyways my tranny stopped doin that .... I can let off the gas and shift all the way to 1st... and the car like just like kicks for one second as it shifts down but then the car is just like idiling going 70 mph in first... or second or drive if i want whatever i put it in.... and then if i hit the gas it just revs up and goes back to idle depending on what gear i'm in if i'm in drive going 70 and hit the gas it will rev up till it hits that gear and then it just grabs it and goes and if i let off the gas it goes back to idle .... iknow this is alotta wording but i'm just tryin to give enough info to see if anyone knows whats up... tranny fluid is full to its proper level and all... if anyone has a clue i'll take anyideas.... thx alot...
vetter
Old Aug 22, 2003 | 07:57 PM
armac's Avatar
Car: 83 ta
never have done that myself but to me that would be alot of wear and tear on the clutches and shift sol. Does the fluid smell burnt does it slip any other time. might try pulling your pan and see whats in the bottom of it. that is unless maybe someone else might have a different idea.
Old Aug 23, 2003 | 12:47 PM
nathan2003's Avatar
Car: Camaro
tranny fluid and filter were replaced like 7 thousand miles ago and the fluid doesn't smell burnt at all.... also tranny seems to be ok cause it does slip hardly at all... its got a little slip but nothing real bad.... still clueless ??
Old Aug 23, 2003 | 07:38 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
same thing happened to mine and another guy in the transmission board. it was determined either the foward sprag or overrrun clutches are toast. the trans needs to be repaired or will lead to severe damage in the future.
Old Aug 24, 2003 | 11:20 PM
nathan2003's Avatar
Car: Camaro
great just what i didn't wanna hear.... more money on my damn car... i just spent 600 bucks in parts this week.... i think i'll let this ride out for a bit... thx for the info though
mustangman65_79
Aug 7, 2015 09:41 PM
nblanchard
Aug 5, 2002 09:37 AM
deadtrend1
Jul 21, 2002 04:08 PM
CUSTOMZ28
Jul 10, 2002 03:06 PM
Christos
Jun 15, 2001 12:25 PM
