Pushrods-long story...
Old Aug 22, 2003 | 08:39 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
OK...the deal is that I have Pro Topline heads, with a flat tappet cam and Comp Cams Magnum SA Rockers (roller tip, made of steel).
By checking the pushrod length with a pushrod length checker I found that the stock length (7.8") will work perfectly, but I can't find any around MPLS over the weekend...SO the question is...can i use stock replacement (I am sure non-hardened) pushrods, like Sealed Power or Federal Mogul, as long as they are the right length? Or should I really find some hardened pushrods first?
Remember, I have self-aligning rockers and no pushrod guideplates...
TIA
Old Aug 22, 2003 | 09:05 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Save yourself the extra trouble and splurge for the hardened pushrods. Don't skimp anywhere on a motor, because in the longrun you're gonna regret it. It's just added insurance.
I put hardened pushrods in my motor BTW.
Old Aug 22, 2003 | 11:16 PM
Engine: LS3
Transmission: 6L80E
I understand that...but are hardened pushrods really necessary? Or is it just something else that is done because everyone does it...
Just curious...
Old Aug 23, 2003 | 02:03 AM
Morley's Avatar
Hardened push rods are required for guide plates, optional on non guide plate installs, but I'd use them for the extra insurance.
Old Aug 23, 2003 | 02:04 AM
Engine: LS3
Transmission: 6L80E
DOH!!...that is what I was thinking too
Just needed to hear someone else say it...guess I will hunt around tomorrow for them...and pay through the nose...wish Summit was in the state at least...
Old Aug 23, 2003 | 10:14 PM
Engine: LS3
Transmission: 6L80E
Conclusion...the ONLY place I could find them in MPLS today was MAS Racing in St. Paul...really sweet place...for same price as Summit...
jrhaus76
Members Camaros
362
Apr 11, 2019 09:47 PM
camarofan13
Nov 28, 2010 08:17 PM
stealth908
Sep 2, 2010 01:20 PM
87ROCZ
Sep 12, 2003 06:58 PM
