Aux Fan Temp Switch
Old Nov 3, 2000 | 06:57 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Aux Fan Temp Switch
I know about the JET Fan Switch that turns the fan on at 200 and off at 185, but it costs $35 and I already have one on my Camaro.
I am looking for a cheap substitute that will work on my other car. Any thread will do, I'll adapt it if I have to.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup.
http://64.176.105.239/octride.htm
Old Nov 3, 2000 | 07:08 PM
Engine: 4.0L
Ok, Ok. I searched the archives and found the fan switch for a 1987 Buick Regal VIN 7 brings the on temp down to 203degF, over 20deg cooler the the stock Z-28 aux fan switch.
86 Camaro Sport
Old Nov 4, 2000 | 06:37 PM
Vader's Avatar
John,
AutoMeter non-adjustable temperature switch, part number 3246. ½" NPT thread, closes at 200°F, opens at 187°F. Two 1/4" male push-on "spade" connectors. $20.99 at the parts stores. Fits in the stock coolant temp sensor holes, or you can put it in a really sensitive location like this:
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
tglennon11
Sep 23, 2015 05:30 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
