Is this a carb or trans problem, need help fast
Old Nov 4, 2000 | 05:07 PM
Marc 85Z28's Avatar
In the past couple of days, my car sputters real bad making left turns. No symptoms on a straight line acceleration. They only happen at low speed, like when turning left from a light, and only in first gear. I can go full throttle around a hard left turn in second or third with no problems. It feels like the car is running on 6 cylinders, and it sounds horrible. Please help!
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N, Edelbrock headers, Catco 3" cat, Hooker 3" cat-back, Richmond 3.73's, Transgo shift kit, JET Stage 2 chip, Hypertech coil, Lakewood LCA's, Powertrax locker, SSM subframes, Centerline Auto Drag's
[This message has been edited by Marc 85Z28 (edited November 04, 2000).]
Old Nov 4, 2000 | 07:13 PM
Vader's Avatar
Marc,
Not having benefit of feeling/hearing the symptoms myself, I can only guess. It sounds like a fuel delivery problem. You might want to check the inlet needle/seat, float binding, and the fuel bowl insert (little plastic "cup-looking-thing" stuck in the fuel bowl to take up space.
I've also heard of the air horn/upper carb gaskets failing on QuadraJets that allow raw fuel to splash directly into the idle or intermediate air bleed holes and metering wells when cornering, but I would suspect that your gear selection wouldn't make a lot of difference in that case.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
