Missing at cruising speeds
Old Nov 3, 2000 | 01:23 PM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
I have a strange problem with a miss. It only happens at lower RPM and while cruising. Under acceleration it doesn't show up. It's very strange because it only happens maybe once a week and only lasts a second or two. I'm thinking its electrical because the Tach bounces when it happens. I replaced the cap and rotor and put on new wires but that didn't help. Could it be a carb problem? I've run out of ideas on how to fix it and it never acts up when I take it to the dealer. Any advise would be very appreciated, thanks.
Old Nov 4, 2000 | 06:56 PM
Vader's Avatar
Troy,
Those intermittent problems can be difficult to diagnose. It's also possible that the pickup coil, reluctor, or HEI amplifier module is failing. You could also have a coil, EST, or primary wiring problem. Check all electrical connections to the distributor. Meter the coil primary and secondary resistance, and check the pickup coil resistance.
It is possible that you have a mixture porblem, but a wildly jumping tach is more indicative of an electrical/ignition problem.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 4, 2000 | 08:28 PM
Troy 85Z's Avatar
Car: 85 Z
I'll check that stuff out tomorrow. Thanks
eightsixseven
Dec 16, 2024 01:50 PM
billybob6110
Sep 24, 2016 09:50 AM
toones
Jan 6, 2016 06:00 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
