NEED HELP it has to be running tomorrow
Car: Black 88 Iroc Convertable
my friends 87 firebird. we had to pull the head to have the exhaust studs drilled and tapped. and are puting it back together but need to know what we torgue the rocker arms to. does anyone know. his winter car **** its tranny the other day so now we cant take our time to fix the bird. its a 2.8.
Keith
85 Berlinetta WS-6
87 Cougar 20th Anniversary
Keith
85 Berlinetta WS-6
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Keith,
On the 4 cylinder you should torque it to 20 ft-lbs.
On the 6 cylinders you torque the rocker arm to studs down to 47 ft-lbs.
Good luck!
-=-Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, platinum plugs, chevy caprice 350 chip.
[This message has been edited by burntblues (edited November 04, 2000).]
Good luck!
-=-Mike
1992 Trans Am
Aug 9, 2015 04:32 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
