Y are GM injectors $137 a piece and SVO's 25 bucks?
Old Nov 5, 2000 | 05:07 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
? Are SVO's lower quality?
Old Nov 5, 2000 | 06:31 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Don't know why. They are both made by Bosch so the quality is there. The pintals are slightly differant though.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup.
http://64.176.105.239/octride.htm
Guest
Guest
Posts: n/a
They are both made by Bosch, so you tell me the difference. Hint: there isnt any.
Old Nov 5, 2000 | 07:00 PM
Smash's Avatar
GM is hell bent on given you the keester lovin' But then again you drive a safer vehicle which costs money. Remember the Pinto, explodes w/ rear end colisions. Oh yeah, and now we have the Firestone cover up. Hmmm, if your suicide prone, buy a Ford car. If your cost concious, buy SVO injectors. They won't kill you.
Brian
Old Nov 5, 2000 | 07:14 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
GM $1,100 Ford $210 I'll take my chances with Ford
Old Nov 5, 2000 | 09:43 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
where can I get the svo injectors from?
-=-Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, platinum plugs, chevy caprice 350 chip.
Old Nov 5, 2000 | 09:51 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Summit or Jegs. Look in the Mustang section.
Street Lethal
Apr 30, 2019 12:14 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Street Lethal
Aug 12, 2015 11:33 AM
