weird noises
Old Aug 25, 2003 | 08:09 AM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
weird noises
ok im starting to frequent these boards too much lol, thanks for all your help guys. Now i have yet another problem. I went to go move my car so my mom could get out and go to work. When i tried to start it, it made a weird noise and didn't crank or anything. It sounded like a whizzing and grinding sound, I don't have anyone off hand to help me find out where its coming from but it sounds bad.
Old Aug 25, 2003 | 10:29 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: weird noises
It's hard to determine with that description.... did you try starting the car with the engine cool, or hot?
Did this just suddenly happen, or did you hear strange noises all the while.... finally leading up to this one?
From what you describe though, it sounds like a faulty starter. Does it sound like the starter gear missing the flywheel.... sounding like it's banging and grinding/rubbing against it?
Old Aug 25, 2003 | 05:10 PM
Car: 83 Trans Am
Re: Re: weird noises
It was cool, i woke up in the morning to move it for my mom cause she needed to get out. Starting it in the past sounded funky, i just recently got the car. I think it is the starter, how hard are they to install? It sounds like grinding
Old Aug 25, 2003 | 07:30 PM
Re: Re: Re: weird noises
Their very easy to install, just make sure you use jack stands, and not just the jack itself....
Disconnect the battery, then disconnect the connections leading to the starter & solenoid (the solenoid is right on top of the starter).
Disconnect the starter (only two bolts), then replace with the new one. Before you make you're electrical connections.... make sure it's lined up correctly, and use shims if needed.
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
