heads?
Old Nov 5, 2000 | 09:55 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
heads?
i have a carbeurated 350 with performer intake and crane energizer cam. I am wondering what to do about heads. SHould i get mine ported and polished? rebuilt? or should i just suck it up and buy an aftermarket set? I am looking for the most power i can get without losing too much drivability, and without making me go broke. Nitrous is also on the way, if that makes a difference or not, i dont know. thanks for your help
Old Nov 5, 2000 | 11:08 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I would go with a set of aftermarket aluminum heads like Trick Flows or AFR's.If you were to take your heads somewhere to have them worked it would only cost a little more to go ahead and get the aluminum heads.Plus you save alot of weight.
Superman
Rev'n to Seven
Old Nov 5, 2000 | 12:37 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
what kind of prices am i looking at for a new set of heads, ( like trick flows)? would i lose a lot of driveability with them? will my headers mount to them?
Old Nov 5, 2000 | 01:05 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
what about vortec heads? Im told these are good also. what prices do they run?
Old Nov 5, 2000 | 09:45 PM
AA89GTA's Avatar
Engine: 355 TPI
Zupman, I'm looking at getting new heads for my 5.7 GTA. I'm going with the AFR 190's. I've heard nothing but great things about them. They are more expensive than most others, but I'm already spending a fortune to rebuild my engine...what's a couple hundred more? HA!! Anyway they are like $1250 ready to install. Check 'em out at www.airflowresearch.com
--Aaron
'89 Trans Am GTA 5.7
Old Nov 5, 2000 | 11:09 PM
TheKid's Avatar
you can get a set of vortec heads from scoggin dickey for 400 bux..and they rock..i have a set on a 350 right now and they rock...hope this helps.
1990 Firebird
(400+HP 350 still in progress)
Complete custom interior
License Tag `URLOSIN`
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
