disconnected vacume advance
Old Aug 25, 2003 | 11:02 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys I disconected my vacume advance of my dist. it seems to feel a little better. Today I changed the plugs and put an accell cap and rotor on and changed the curve springs with the lightest ones so i woudl get the most mechanical advance and reset my timing to 9degrees. Well I haven't drove it since i did all this but is it alright to run with the vacume advance off?? What are the disadvantages and advantages of doing this? thanks
Old Aug 26, 2003 | 12:15 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
No advantage.
The disadvantage is less adv at part throttle/light load situations.
Whenever the timing is advanced as much as it can be, before knock, the engine is at maximum efficiency (as far as timing goes).
The cool thing about vacuum advance is it puts the timing as far as it will go (without knock) while the engine is under a light load.
I bought my '72 with the vacuum advance unhooked. I would make 2 trips into town and back for a total of ~ 100 miles. Then I'd have to fill up.
Now that I've hooked it up, I can make 3 trips there and back. Chalk up another 50 miles to the vacuum advance.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
2012sergen11
Oct 13, 2015 07:38 PM
Damon
Sep 26, 2015 04:29 PM
