Need wiring help!
Old Aug 26, 2003 | 12:31 PM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Need wiring help!
As most of you know my IROC was wrecked by me some time ago. Well some ricers thought it would be funny if they ripped out the wires of my car. pretty much every wire in the wiring harness...I have put most of them back buy memory....But something is wrong....I just put a new alt on...and i have the hot wire from the alt. running to the batt. of course. and then I have it grounded....but there is nothing running to my starter....could someone tell me how to wire that up and what kind of wire i need to use because its gone-cant find it anywhere.
Old Aug 26, 2003 | 05:39 PM
anyone?
Old Aug 26, 2003 | 05:51 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if your missing everyhting then maybe your best bet would be to go to a junk yard and get a complete wire harness and wiring for the accessories from a similar third gen. For the starter, the very least youll need is a main large gauge wire running to the starters main teminal from the + terminal of battery, a switched 12 volt wire to engage the solenoid, as well as a large ground wire to the cylinder head. Ive seen similar wires that are pre fitted with terminals available at most autoparts stores.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
