Question for everybody to answer
Old Nov 6, 2000 | 08:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I need injectors.
A. They have new 22lbs for $360 and i'm getting a performance resource chip $210 Total $570
B. 24lbs for $210 , but would need ed write custom chip $350 Total $560
C. Buy used (take chance) injectors for about $80 then have them done at cruzin $90 (they may be broke ones) and then a chip 210. Total $380 + Take the chance of buying bad injectors.
A, B, or C ?
Old Nov 6, 2000 | 08:45 PM
84IROC's Avatar
First of all do you really need the higher flow injectors ie....for future engine upgrades or are you just wanting to try to gain power by doing this? Be careful to not assume bigger is always better.
As for the price I usually look only at the difference. For only $190 more you can be asured of functional equipment plus when you add the $190 to the over all cost of the engine it will seem negligiable.
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Nov 6, 2000 | 08:50 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I got full intake ,1.6 RR ,and exhaust and dont really need the 24#'s but they are accually CHEAPER then the 22#'s Ed write said with his chip the 24#s would be perfect fo rmy car. I know i probebly will upgrade even more so i'm thinking about going with the 24#'s
Red iroc-z 305
Sep 30, 2015 05:22 PM
TEEZER TA
Aug 30, 2015 06:35 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
