what serptine belt for zz4?
Old Aug 28, 2003 | 01:24 PM
BADBIRD009's Avatar
ok i am going to use my accesories and brackets from a 305 tbi to put on a zz4. i will have tensioner, alt, water pump, crank, and power stearing pulleys. what is the part number, or length of serpintene belt i will need to use?
Old Aug 28, 2003 | 02:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you deleting AC & A.I.R.?
Old Aug 28, 2003 | 02:51 PM
BADBIRD009's Avatar
yes.
Old Sep 6, 2003 | 12:18 PM
BADBIRD009's Avatar
well?
Old Sep 6, 2003 | 11:24 PM
five7kid's Avatar
Only reason I asked is because you didn't specify, and unless you were doing that you could just use the same belt.
Sorry, but I don't have a clue to the answer. Perhaps someone else will. Or, if you can find info about delete kits, it might include that tidbit.
Old Sep 10, 2003 | 07:55 AM
BADBIRD009's Avatar
ok factory brackets wont work. sooooo, i am looking into the march v belt to serpentine setup. will the power steering pump from an 89 305 tbi work with this setup?
http://www.jegs.com/cgi-bin/ncommerc...57&prmenbr=361
it is the part all the way at the bottom of the page.
J
Old Sep 10, 2003 | 09:20 AM
BADBIRD009's Avatar
nevermind, i called march i need 22065, to use my power steering pump and alt, and also keep my stardard flow water pump.
Old Sep 10, 2003 | 09:35 AM
five7kid's Avatar
Good move. Straight from the horse's mouth.
Thanks for sharing the information.
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
