Fan won't switch off
Old Nov 4, 2000 | 08:09 PM
Sharpcorner's Avatar
I came home from work today and my fan stayed on after I turned off the engine. It won't shut off. It is an L03 and it is still stock. I need to fix this tomarrow because this is my daily driver. Please help.
Old Nov 5, 2000 | 09:24 AM
Well, I think that I have it down to the AC system. I noticed that my compressor is very eratic and making abnormal sounds. The good news is that my fan shut off. How much do these compressors cost?
Old Nov 5, 2000 | 01:07 PM
Vader's Avatar
Sharp,
I would guess that the problem is more likely with the fan relay sticking than the AC compressor. The compressor and the ECM control of the fans will terminate when the ignition is shut off. The only way for the fans to remain on after shutdown is if you have shorted wiring or a sticking fan relay.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 5, 2000 | 03:13 PM
That makes sence. So can you tell me where the relay is so I can get a new one?
Old Nov 7, 2000 | 03:40 PM
BTT
Old Nov 8, 2000 | 04:31 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
On my 1991 LO3 the fan relay is located on the drivers side firewall. btw, there are two relays located on the firewall: one is the fuel pump relay (closer to passenger side) and the other relay is for the fan (closer to the driver side).
hth!
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
