starter heat soak??
Old Nov 7, 2000 | 03:08 PM
MrMike99's Avatar
starter heat soak??
what exactly is this?
is it the solinod not functioning when hot?
or
is it the starter mechanisum?
I have changed solinods and installed a Moroso heat shield and under the right conditions(always at the worst time) the starter won't work intill I let the car set for awhile 1/2-1 Hr.
90' GTA Blk/Blk WS6
355ci 10:1
6085 Aluminum heads
SLP Hdrs&runners
52MM TB 24#inj
compcam
510/510-220/230 114
Crane gold RR 1.5
Performance Resource chip
700R4 rebuilt by MEwith all the trick stuff.
Old Nov 7, 2000 | 04:24 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
MrMike99...Its the solinoid, At least it was on my car. After I installed a set of hooker headers my car did the same thing.
Summit sales a kit for around 25.00 that mounts the solinoid away from the sarter. Its basically a Ford solinoid. I never had a heatsoak problem after I installed it. It very easy to install too.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
[This message has been edited by MikeH (edited November 07, 2000).]
Old Nov 8, 2000 | 08:07 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Well I just explained my "phantom no-start" on another post, so not gonna get into it again in detail. In a nutshell, I was having a similar problem and what has (seemingly) fixed it for me was to remove all cables from the starter, battery, and grounding points and clean the terminals of each with a wire brush - that includes the terminals of the batt, starter, and block. Haven't had a problem since.
KAM
Old Nov 8, 2000 | 08:19 AM
Biochem's Avatar
Car: 2002 SOM z28
This just happened to me last night... at the worst time. Basically the car overheated in traffic around 6pm. I got it into a parking lot and tried again around 8pm and again at 10pm. It would just rapidly tic.
Finally, I giggled the positive cable and BUZZAP! I think I shorted it against the heat shield that I installed last March to keep the heat thing from happening with the new starter... which it has happened about 3 times since. IMO, the heat shield has caused more problems then it's fixed!
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
3rd gen money
Oct 11, 2019 09:57 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
