Can you still buy "new" gas tanks for third gen's ?
Old Nov 7, 2000 | 08:45 PM
JJ's Avatar
JJ
I think my fuel pump is going on me, I switched from tpi to carb and went with the mallory three port regulator. Everyday I start the car, I have to reset the fuel pressure - I've had ranges of 3 - 12. Obviously, I can't get the car tuned worth crap. I guess the in-line gauge could be screwed up, I'll check that I guess. I want a new tank while I'm at it, plus a new pump. What pump would you recommend to put me at carb psi levels, I want to get rid of the regulator. Should I go with an electrical in-tank or in-line ? I want a good fuel supply as I plan on a 100 or 150 shot of NO2 on an engine that should be around 375 or so NA. I sum up my babble, I want a good pump, probably electric, (are vortec heads drilled for mechanical pump?) in-tank or in-line. Hopefully I can do a new tank while I'm at it.
Old Nov 7, 2000 | 11:38 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
not sure about the pump, but you can offer a catalog online from YEAR ONE. its called NEXT GENERATION. they have what your looking for
Old Nov 8, 2000 | 09:21 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You're staying with the carb? If so, I'd say get a regular electric pump, not one that goes inside the tank. In fact, I believe I've read that an external pump will still suck gas through a dead in-tank pump- eliminating the need to remove the old pump from the tank.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 8, 2000 | 10:26 AM
JJ's Avatar
JJ
I'm trying to find some information about putting an electric pump in-line with my stock pump disabled, but have not found what I'm looking for yet.
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
