Is it worth it?
Old Aug 31, 2003 | 04:53 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Is it worth it?
Hi,
I'm looking at my ZZ4 camshaft and I wonder if there're any advantages to expect if I'd put another one: 219/219@.50; 112 lsa, .525 lift both in/ex. This is going to work with HSR, ported L98 heads, dual 2 1/2 ex. and possibly higher-than-stock converter. PROM needs to be reworked, so it's not an add. problem. Blueprinted LT1 rotating assy shouldn't limit peak RPM at lower than 6200-6300; the valve springs and guides will take .550" lift.
What do you think about quick change in my project? Is it worth extra $75? As in my sig. emmisions are not concerned as a problem ;-)
Thanks i.a.
Mike
Old Aug 31, 2003 | 07:15 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
well it depends...
1. do you have an extra $75?
2. how streetable do you want it to be?
3. whats wrong with the cam you have?
just some thoughts to ponder......
Old Sep 1, 2003 | 08:42 AM
z_power's Avatar
Car: '89 GTA
Hmm, after answering to myself I've decided to go with ZZ4 cam. There's nothing wrong with it; I've thought about changing because my engine is assembled now, so cam swap doesn't mean any extra work. I think there's still a lot of points in my car, that require $75-or-more investments
Old Sep 1, 2003 | 08:36 PM
Car: 88 IROC
my point exactally
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
