high oil pressure
high oil pressure
what are some of the problems that goes with high oil pressure? my oil pressure stays high at all rpms. There is nothing wrong with my oil pressure gage, i even hook up a mechancial gage. could there be something in my oil pssages?
high oil pressure
i was using 5w-30 at frist because of tapping noise and the temp was 90 degrees and oil pressure at 65 psi so i change to 10w-50 and the oil pressure is still high.
Car: 92 Camaro RS
Engine: 305 TBI
What exactly are you calling high? 65 lb. is not all that high, I think anything over 80 might be too much, much more than that and the pump drive shaft might twist off, I know a guy that used to brag about his engine having 100lb. cold , that is untill the shaft twisted off.
ambainb
Apr 25, 2016 09:21 PM
