Hard Starting after 10 Minute Cruise
Old Sep 1, 2003 | 02:45 PM
BranZ's Avatar
Car: 1991 Z28
Engine: 5.7
Transmission: A4
Okay, here is the problem. I have a 91 Z28 5.7. It runs fine when you crank it up cold. It starts right up. I can get in it and drive it. It will idle fine at stop lights. It never has any hestiation and has plenty of power. Once I stop and let it sit for 5 to 10 minutes it will not start. It will crank over fine. The car never got above 160 degrees. Auto Xray numbers look good. I have replaced the fuel pump with Walbro 255. I have replaced the module in the distributor. I have replaced the coil and still no luck. I replaced the computer. Any ideas. This is really killing me. The VATS light comes on but goes off in two seconds. The alternator seems to be charging fine. I am going to try a different battery tonight. Any ideas and suggestions? Thanks, BranZ
Old Sep 2, 2003 | 03:22 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I had the same problem, It was heat soak on the starter from the headers.
This fixed it forever Heat shield
Old Sep 2, 2003 | 04:00 PM
88fbird's Avatar
Car: 84 S-10:(
I had that problem. I didn't think it was the starter because it would turn over fine. I just had to crank it forever before it would fire. It turned out that I had a couple fuel injectors that were leaking. I replaced them, and the problem went away. See, while the car is sitting, the cylinder is just getting filled with fuel. So, it is just like starting a flooded car. Hope this helps.
Fbird
Old Sep 2, 2003 | 05:06 PM
BranZ's Avatar
Car: 1991 Z28
Engine: 5.7
Transmission: A4
Starting Issue
I just do not understand why I have the problem after the drive. The car cranks up cold with no problems. You almost can not get you hand off the ignition fast enough. Performance is excellent. The gas mileage has not been the best but I just run it up and down the road. This problem started when I put in the used LT1 injectors. I hope this is not the problem. Any other ideas?
Old Sep 2, 2003 | 06:34 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
like fbird suggested, get your injectors examined n tested.
Old Sep 2, 2003 | 07:39 PM
88fbird's Avatar
Car: 84 S-10:(
When it happen to me, the car ran fine. It had good responce, and no problems starting it in the mornings. But, if you let it set for a couple minutes, it would take forever to actually start. There are a couple things you can do to check them. That is where I would start. Sounds like you have eliminated everything else.
Later,
Fbird
Old Sep 2, 2003 | 10:26 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
posted by BranZ
Sounds like the injectors to me.
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
cstrobel65
Aug 15, 2015 10:19 AM
