HELP! Car won't turn over... can I disconnect the MSD box?
Old Nov 9, 2000 | 08:32 PM
Biochem's Avatar
Car: 2002 SOM z28
I just put in a Carter Street pump and a new battery and now the car won't turn over. I drove it a few times today, but now it is stalled and acting like it is fouled up or something. It cranks over and the battery is fully charged, but it won't fire. I tried to spray some carb cleaner down it, but still nothing. Maybe my MSD box decided to go bad all of the sudden? Can I leave the power wires attached and just disconnect the wires that go to the HEI and reconnect the stock wires? I am despirate!!!
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Nov 9, 2000 | 11:35 PM
MikeC.86Roc's Avatar
Does the Starter turn over? If it sounds like its turning real hard maybe its hydrolocked? I dunno, I would rule this out in normally but you replaced the fuel pump, so maybe it is filling the cylinders and hydrolocking? Try this... Take the plugs out and turn it over. This is the easiest way to see if the engine is turning free...
Old Nov 10, 2000 | 07:16 AM
Biochem's Avatar
Car: 2002 SOM z28
Pulling the plugs is really not an option in the parking lot where the car is. From what I hear from someone else with the same symptoms, I assume the plugs are fouled all ready. I think my MCS may be bad or something. I just really need a way to drive my car home 3 miles from the gym...
The starter is relativly new too. Battery is only a few days old. It cranks over, but never fires up. In fact, when I stop cranking, a puff of gas shoots out the top like the crank turns back a halk turn or so.
Old Nov 10, 2000 | 09:04 PM
Is the starter spinning over at the same speed it used to? You really should do a plug check to see what is going on inside the cyls. Why not get an inline spark checker while you're at it too.. I got one that cost me like 6 or 7 bucks, the light will light up if you have fire on that plug wire. Even if you do have fire, its a great tool to have.
BRoss99
Aug 10, 2025 05:08 PM
1992rs/ss
Jan 31, 2025 05:10 PM
Ghettobird52
Jul 5, 2024 11:18 PM
9192camaro
16
Feb 3, 2019 12:21 AM
BrianI
Aug 9, 2015 11:52 AM
