Help! Broken Exhaust Header Bolts
Old Nov 10, 2000 | 08:32 PM
Geoff BSA's Avatar
Just picked up a 86 Camero for my son, 2.8L with 174K---engine runs great and strong. Only problem is two bolts on left side (back) and one on the right side front (lower) have the heads missing and are leaking exhaust. At least one is broken at the block. Any tricks for removal??
Is this a common problem??? Should I live with it until the engine needs replacing?
Thanks!
Geoff Ullmann
San Jose, CA
Old Nov 10, 2000 | 09:14 PM
Vortex_89rs's Avatar
Get some easy outs. They look like drill bits that are tapered and have steep threads around them. You drill a hole through the bolt, put the easy out in and then hook a wrench to the easy out and twist the thing off. I did this to the bolts on my 88 rs that had a 2.8 - same bolts too! Those easy outs are the best. They are about $25-30 a piece, but well worth it.
Vman
1989 Camaro RS
2.8 V6
K&N's
700R4 tranny
Cragar Street Pro rims (old Series 30)
Pioneer DEH-P3000
1969 Camaro SC
350 HO from a Vette
Turbo 350 tranny
In the process of being restored
Old Nov 10, 2000 | 10:36 PM
Bort62's Avatar
untill you break an easy out off in the Hole
Then its a 70$ torch out and helicoil At the machine shop
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Reddeath210
Oct 6, 2015 08:20 AM
transaero
Aug 31, 2015 01:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
