Whattdya think?
Old Sep 3, 2003 | 03:11 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Whattdya think?
What do you guys suspect this engine would have in Hp and torque?
a 350 with a .477 lift cam
port and polished heads
2.02/1.60 valves
edlebrock intake
600 cfm 4bbl carb
and headers
Also, tuned well, what kind of gas mileage would it get?
Old Sep 3, 2003 | 03:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What cam? What heads (882s, 434s, 186s, Dart Pro 1 220s)? What Edelbrock intake (Performer, NASCAR Super Victor, etc.)?
A 600 carb will flow a little over 300 HP worth of air. Remember, HP = energy per time; energy is released by burning gas molecules; burning gas molecules requires air (or some other source of oxygen); so the bottom line is HP = CFM (air molecules per minute).
It will get something less than 24 miles to the gallon. Maybe not much less, maybe a whole lot less. That will depend on all of the above, plus the gears, the trans, and above all, driver habits.
Old Sep 3, 2003 | 03:47 PM
k...I'll try to find that stuff out
He thinks it has 3.55 gears, and it has a turbo 400 tranny
Old Sep 3, 2003 | 08:01 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Heh ive noticed that there is a direct corelation between my gas mileage and how heavy my foot is...good thing i dont wear boots got it bad enough as it is.
Old Sep 3, 2003 | 09:01 PM
K...so it is a 4bolt main from a truck bored .010 over, it has the stock heads just ported and polished and has 2.02/1.60 valves, dunno about cam and intake yet...
Does having heads from a truck make any kind of a difference?
Old Sep 3, 2003 | 09:35 PM
well for some reason, he doesn't know what cam he put in it...just that it has a .477 lift and may be a comp cam , and he doesn't know about the intake either
So I know there is very limited information here sorry about that, since I have only owned my V6, I don't know a whole lot about specifics on the 8, but what kind of general performance could this thing have, are there any comparisons you guys could make to engines you have/have seen.
Old Sep 3, 2003 | 09:44 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
from the sounds of it hed be damn lucky if he was pushing out 300 to the wheels....id expect him to be below that mark
