Car running real rough under power...
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
When I put the car under power, car bucks and sounds like it is missing real bad. Then it smoothes out and goes. This morning the car actuallly loaded up then died...then started back up...last time it did that it knocked the coil out and would not start. Coil has been replaced by same oem speck. Sounds to me like it is not mechanical but rather electrical...What are you guys' thoughts?
91 Firebird 305/TBI - cam:.420/.442 204/214 - Hooker 1 5/8" headers - TFX PaceSetter Cat-Back - 3.42's Auburn Pro Posi - ASCD Ram-Air hood - Polished Formula Wheels w/Futura's - Open element - .5" Corian TB spacer - Lakewood LCA's - Hotchkis Lowering Springs - KYB Struts/Shocks - 14.78 @ 97.5 mph(G-Tech) - MacEwen MotorSports Whiteface Overlays - 412ci sb waiting to go in this spring.
My Homepage
My Homepage
Car: Take
Engine: Your
Transmission: Pick
How old are the spark plug wires? Usually a misfire under load is ignition related, and if the plug wire is bad enough, it may be putting too much stress on the coil wich may have killed it.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
SSM SFC,
Boxed LCAs,
8mm Accel wires, Flowmaster Exhaust,
16" GTA rims.
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
Ported Plenum,
SSM SFC,
Boxed LCAs,
16" GTA rims.
'97 Bonneville SSE
Car: 1991 Firebird
Engine: 412ci/sb
The plug wires might be just a year and a half old. They are accell 8mm. Now after I changed the coil I did have the #2 wire resting on the header for a day or so before I caught it. It did not burn through but just left a small white spot where it was laying. It seems like it might be the coil...maybe that cheap autozoo coil is the culprit. I might go ahead and get a new coil. To narrow down the problem.
