Are G-Techs any good?
Old Nov 9, 2000 | 08:52 PM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
Are these very accurate and reliable? Are they worth the money or more of a novelty thing? Thanks
Old Nov 10, 2000 | 03:10 AM
BadSS's Avatar
They're worth the money if nothing else as a tuning tool. Most seem to be within .25 seconds and a couple mph of track times. Some are off more. However, they are consistant,, whether they match the track time or not. I could not imagine tuning in a car (especially a carbed one) without one.
Old Nov 10, 2000 | 12:35 PM
Troy 85Z's Avatar
Car: 85 Z
Where is the best place to get one and about how much would it cost. I was thinking about getting one before I start any mods to determine how much each one helped, so I guess consistancy would be better then it's accuracy. Thanks
Old Nov 10, 2000 | 02:01 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
They've got 'em in Jeg's and Summit. They run $149.99.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Nov 10, 2000 | 07:23 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
G-techs are awsome. They have never been more than .10 off from my actuall 1/4 mile times. The MPH has been off up to 5 MPH, but I feel that the 1/4 time is more important anyway. I am borrowing a friends, and I will eventually buy my own. I was shocked, but its very accurrate.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
SSM SFC,
Boxed LCAs,
8mm Accel wires, Flowmaster Exhaust,
16" GTA rims.
'97 Bonneville SSE
Old Nov 10, 2000 | 10:25 PM
82z's Avatar
82z
You think the e.t. is more important than the mph! E.T. is more everyhting going right but mph is pretty much independant especially when dealing with tuning issues as mph is a function of horsepower. For example my car g-teched at 14.62 at 102.4. It is not unreasonable to say that 102.4 is
13.99-14.00 territory. Why didn't I run .6 seconds quicker? Most likely driver skill and tires.(probably more driver than tires) That (E.T.) brings a lot of variance if you use it for tuning purposes. ------------------
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
[This message has been edited by 82z (edited November 10, 2000).]
Old Nov 10, 2000 | 10:31 PM
Bort62's Avatar
I got a good question about Gtechs, How Do they work ? do the Get MPH from the speedo or what? I understand That acceleration can be measured as a factor of Gforces, and Weight of car + time elepased and all that Can lead You to Hp, ET, 0-60 and So on, But what I dont understand is how It can calculate trap speed, Or Does it Simply link into the speedo ?
My speedo Like many of yours is really screwed due to tire size and gears, I havent botherd to re gear it yet Because I havent decided on a tire size and rear end ratio, PLus, When im Racing Vrs driving, I will be using differnt sized rear tires, same as when AutoXing,
Anyone able to Clue me In on this before i drop 150 bucks on this thing ?
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
Old Nov 11, 2000 | 03:16 AM
Mark305TBI's Avatar
It bases trap speed on the acceleration forces that it detects, it in no way interfaces with the speedo on your car. Accurate times require accurate weight measurements and a flat road to run the test on. Give it these two things and it'll give you a good estimate...
-Mark W.
Old Nov 11, 2000 | 09:26 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
The reason the MPH is high on Gtech is because it measures (calculates) MPH at the finishline of the quarter mile where as tracks average the mph in the last few feet (100 feet?) you typically want to subtract around 3-4 mph from the mph on a gtech to get what a track would give you
but the important part is that they are consistent, the last time I used one was on a friends 95 mustang cobra with him riding shotgun, the first run i hit a 14.4 at like 104 mph
the second run was EXACTLY the same in terms of launch and shift rpm and road, the only difference was that i heard the tires chirp second gear, the gtech showed a 14.41 at 103.5 on that run
i like gtechs
Old Nov 11, 2000 | 10:15 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I agree with Pablo on the consistency of the G-Techs. That's what makes them a useful tuning device. Sure the mph may be reading high, but it is consistenly high, therefore you can gauge the effect of your modification/tuning.
Old Nov 11, 2000 | 11:34 AM
Troy 85Z's Avatar
Car: 85 Z
I wasn't really looking for it to give me an accurate ET and trap speed. I just wanted good consistancy for tuning and trying different mods. From what I've heard they all seem a little high on trap speed but that's OK as long as the consistancy is there.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
